1998 V5 STI TYPE R REBUILD @STI TUNING
davelegacy
Member Number 16
[size=11pt]OWNER: JONATHAN
USERNAME ISDC: JONATHAN STI
PROJECT 400BHP
FAILURE WAS MELTED PISTON.
CAR FULLY FORGED BUILT WITH A 2.25L. CAR DID NOT HAVE ITS PROPER STI6 HEADS WHICH IS COMMON AT THIS STAGE OF CARS WITH ENGNIES GETTING SWAPPED. SO WE SUPPLIED STI6 HEADS AND WERE FULLY SKIMMED-PRESSURE AND VACUUM TEST AND SHIMMED. AIM IS 400 BHP BUT WILL RUN AREA 350BHP AFTER MAPPING TEMPORARY. WITH 2.2 BLOCK WITH OVERSIZE BORE AND HONE AND BLOCK FACED. REBUILT USING SUBARU CRANKSHAFT, ACL RACE SERIES MAIN AND BIG END BEARINGS, EAGLE FORGED CONRODS WITH ARP BOLTS, WISECO FORGED PISTONS, COSWORTH HIGH TENSILE HEADSTUDS, COMETIC HEAD GASKETS, COSWORTH KEVLAR TIMING BELT, NEW SUBARU TIMING TENSIONER, ALL x4 IDLER PULLEYS, EXEDY PINK ORGANIC CLUTCH KIT, FLYWHEEL SKIM AND SPIGGOT BEARING, NEW FRONT AND REAR CRANKSHAFT SEALS. AND ANY GASKETS THEREAFTER NEEDED RENEWING. AND FRESH OILS, COOLANT AND PLUGS. NGK 7'S.
ALSO WE WENT BIT DIFFERENT ON THIS WITH PURPLE INLET MANIFOLD AND ROCKER COVERS. ALSO ADDED WAS A FRESH EXHAUST MANIFOLD FROM A 2005 STI AND VF28 DROPPED IN FAVOUR OF A BRAND NEW VF48 TURBO.
STi TUNING
BELOW IS PICTURES OF BUILD AND CAR:
[/size]
Depends on engine cc and usage. And of course turbo choice. Area 365=375 lb ft from our experience. Not sure advertised lb ft rating.
Also to note thats on 230mm 5MT version.
Great work Dave. :thumbsup:
Manifold and rocker covers look the business.
She looks a sweat motor also. :subaru:
Looks great Dave. Quality build. The purple works really well. Fair play to the owner for going with something different.
Looks great but mostly covered by reg plate. Will be moved or smaller reg I presume?
That will be upto owner to choose location of reg.
I am not concerned about plate location causing chargetemps of any concern.....
