Mapping in September
I'm out - engine failure.
1. scoobycolm. my00 type uk turbo ecutek tweak
2. Forester Sti (Dan) '06 Forester Sti ecutek tweak I'll remove my name from Scooby Ireland list!
3. Nic Spec C - Simtek tweak
4.coopster my05 forester ecutek tweak - date depending if its the weekend 11th or 12th sept thats a go thumb
5.
6.marek-irl - simtek tweak , If I'll return from vacation
7. keith555 - v3 uk turbo - simtek tweak - date depending
8.larsti8- v4 type r, full simtek .antilag and launch setup
9. Jackswagon, v6 classic. Simtek tweak. Date depending on if its 11th or 12th sep as away untill then.
10. hiwd, V4 classic. Apexi Power FC map
[quote author=RudeBoy link=topic=25227.msg303538#msg303538 date=1281822078]
sorry to hear that
:icon_cry:
hope you get it sorted with the least hassle possible :icon_sad:
1. scoobycolm - my00 type uk turbo ecutek tweak
2. Forester Sti (Dan) - '06 Forester Sti ecutek tweak I'll remove my name from Scooby Ireland list!
4. Coopster - my05 forester ecutek tweak - date depending if its the weekend 11th or 12th sept thats a go thumb
5. marek-irl - simtek tweak , If I'll return from vacation
6. keith555 - v3 uk turbo - simtek tweak - date depending
7. larsti8 - v4 type r, full simtek .antilag and launch setup
8. Jackswagon - v6 classic. Simtek tweak. Date depending on if its 11th or 12th sep as away untill then.
9. Hiwd - V4 classic - Apexi Power FC map
10.
out for this one :icon_sad: some bills to catch up on for now :angry1:
4. marek-irl - simtek tweak , If I'll return from vacation
5. keith555 - v3 uk turbo - simtek tweak - date depending
6. larsti8 - v4 type r, full simtek .antilag and launch setup
7. Jackswagon - v6 classic. Simtek tweak. Date depending on if its 11th or 12th sep as away untill then.
8. Hiwd - V4 classic - Apexi Power FC map
9.
Whats the story with mapping a 95 wrx? Is it possible? What would be the best bet? I know the car is already mapped for regular unleaded. Also i heard that it should be remapped when putting a induction kit on. This true?
[quote author=dannywrx link=topic=25227.msg305539#msg305539 date=1282510390]
ideally it should be mapped for induction kit, they are not find on 95ron fuel if that's what you mean by regular unleaded but I would also be happy to check it as is with detcans and wideband to check if it is safe.
options are :
ESL Daughter board
SimTek
or find a secondhand Apexi PowerFC..
pricing is www.jollygreenmonster.co.uk if you want any further help / advice just drop me an email.
Thanks
Simon
[quote author=narked link=topic=25227.msg305705#msg305705 date=1282565934]
Simon
whats the difference between simtek and solaris ecu's
Regards
David
solaris has been renamed syvecs www.syvecs.co.uk
Basically the simtek is very good, syvecs is the best there is, budget needs to then dictate which suits you.
Both quick processors and map defintion is high so you get a very smooth and responsive car.
Both map based so not using the maf sensor anymore.
Simtek has 2 maps, Syvecs upto 8 maps.
Syvecs has internal data logging..
Simon :)
can the SimTek tweaks (not you Nick Spec C or Marek as I have it already) get the ecu number off the ecu board please it will be E1S.YY.XXXX where YY is the year of ecu (ie. 96 for 93 to 96, 97 for 97 and 98, 99 for 99 and 00 and 2K for 01 onwards) and XXXX is the serial number of that ecu.
Thanks
Simon
6. larsti8 - v4 type r, simtek tweak .antilag and launch setup
9. Alex - Syvecs
10.
11.
[quote author=keith555 link=topic=25227.msg305930#msg305930 date=1282601768]
Do you have a date set Simon. :thumbsup:
Damn sorry I thought I had posted date.. been on holiday and now getting back up to speed.
8th and 9th September possibly 10th also if required.
Simon
Sorry I'm out Simon as I'm away that week. :icon_cry:
I know lads have offered to bring my car over for me but would like to be there to have my mind at rest.
Cheers :thumbsup:
Keith
Will have to remove my name from the list as I'm not back on those dates you have set Simon unfortunately, :thumbsup:
Are you back over again this side of xmas ?
